You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an alternative browser.
Pontiac Grand Prix supercharged gxp No battery charge
- Thread starter NORMANREH
- Start date
Yes I need helpWhats the story? You need help or just saying no battery charge?
- Sep 29, 2024
- 104
Have you used a multimeter to see that the alternator is putting out the proper voltage? Have you also used it to see what it’s doing at the battery? Have you had the alternator set a light?
It doesn’t sound like the alternator is putting out voltage. When the engine is running & the alternator is working properly you are running on the alternator’s power, not the battery.
New member
- Nov 15, 2026
- 3
I understand this is an Old Post I hope you had found the problem but this point either an alternator or a bad batteryWhats the story? You need help or just saying no battery charge?
New member
- Nov 15, 2026
- 3
first thing you must do if you haven't already it's get a multimeter and test voltage at the battery be at least 13.5v to14.5 that'll tell you that your voltage regulator is working but not necessarily if it's putting out enough amps the best way to do it is to get something that would test the average output something that everyday guys at home may not have when it gets stuck going to a shop too check that.Yes I need help
Similar content
Most view
View more
Intro Sandhills_pontiac
