Pontiac Grand Prix supercharged gxp
Pontiac Grand Prix supercharged gxp No battery charge
NORMANREH
New member
Whats the story? You need help or just saying no battery charge?
So I change the alternator and the battery just drains out while I'm driving it.
Have you used a multimeter to see that the alternator is putting out the proper voltage? Have you also used it to see what it’s doing at the battery? Have you had the alternator set a light?
It doesn’t sound like the alternator is putting out voltage. When the engine is running & the alternator is working properly you are running on the alternator’s power, not the battery.
Yes I need help
first thing you must do if you haven't already it's get a multimeter and test voltage at the battery be at least 13.5v to14.5 that'll tell you that your voltage regulator is working but not necessarily if it's putting out enough amps the best way to do it is to get something that would test the average output something that everyday guys at home may not have when it gets stuck going to a shop too check that.
