How to Swap 2000-2005 Monte Carlo Taillights to 2006-2007 Taillights
ThatSlow.W204
Social Media Manager
Why Upgrade to 2006-2007 Monte Carlo Taillights?
If you own a 2000-2005 Monte Carlo, upgrading to the 2006-2007 taillights is a fantastic choice for both style and functionality. Here’s why:
  • Modern Aesthetic: The 2006-2007 taillights feature a sleek red lens design, giving your car a more modern and cohesive look compared to the 2000-2005 taillights, which have a clear lens.
  • Durability: The 2000-2005 taillights are prone to delaminating over time, leading to an unsightly appearance and potential light failure. In contrast, the 2006-2007 taillights are designed to avoid delamination entirely, making them a reliable and lasting upgrade.
This upgrade not only enhances your Monte Carlo’s appearance but also ensures long-term reliability for your taillights.
The swap is straightforward and requires no major modifications. Follow these steps:
Step 1: Remove the Old Taillights
  1. Open the trunk and pull back the trunk liner to expose the taillight retaining nuts.
  2. Use a 10mm socket to remove the nuts (three per taillight).
  3. Disconnect the 2000-2005 taillight harness and carefully remove the old taillights.
Step 2: Prepare and install the 2006-2007 Taillights
  1. Transfer the 2000-2005 harnesses to the 2006-2007 taillights:
    • The bulb sockets from the 2000-2005 harness fit into the 2006-2007 taillights without modification.
  2. Position the 2006-2007 taillights in place and align them with the mounting points.
  3. Secure the taillights using the original retaining nuts.
Step 3: Test and Reassemble
  1. Test all lights (brake, turn signal, and running) to ensure they work correctly.
  2. Reinstall and secure the trunk liner.
And that's it!
With this upgrade, you’ll enjoy the stylish and durable 2006-2007 taillights, eliminating the issues of delamination while giving your Monte Carlo a refreshed look. It’s an easy and worthwhile improvement!
Feel free to reach out if you have any questions or need more tips!
