- 285
Engine Removal Guide: Pontiac G6 with 3.6L V6 (LY7)
Applies to: 2007–2009 Pontiac G6 GXP with 3.6L LY7 V6 (FWD automatic)
Difficulty: Intermediate – Requires basic tools, jack stands, engine hoist, and mechanical experience
Estimated Time: 6–10 hours depending on experience and rust
- Support the engine and trans with a rolling cradle.
- Unbolt the entire front subframe assembly and lift the body upward with a hoist.
This method is faster but requires overhead lift equipment.
Tools & Equipment:
- Engine hoist (2-ton recommended)
- Basic hand tools (metric sockets, extensions, swivels)
- Jack and jack stands
- Wheel chocks
- Screwdrivers, pliers, fuel line quick disconnect tool
- Drain pans
- Ziplock bags & labels for bolts
- PB Blaster / rust penetrant
- Torque wrench for reassembly
Step 1: Prep Work
- Disconnect the battery – Always start here. Negative terminal first.
- Set the car on jack stands – Securely lift the front of the car and support it under the subframe.
- Remove the front wheels – Gives access to the axles and lower components.
Step 2: Drain Fluids
- Engine oil
- Coolant – Open the radiator drain plug or pull the lower hose.
- Transmission fluid – Remove the cooler lines or allow it to drain once axles are removed.
Step 3: Intake and Front End Disassembly
- Remove the engine cover, MAF sensor, airbox, and intake tubing.
- Disconnect the MAF sensor, PCV hose, and throttle body and camshaft sensor wiring.
- Remove the coolant reservoir and move it out of the way.
- Disconnect the upper radiator hose and heater core hoses at the firewall.
- Disconnect radiator fan wiring and remove the radiator fan assembly (2 bolts at top).
- Optionally remove the radiator for more clearance.
Step 4: Electrical Connections
- Label and disconnect all engine harness plugs – injectors, coil packs, O2 sensors, VVT solenoids, etc.
- Disconnect the engine-to-chassis grounds.
- Unplug the alternator, starter, and AC compressor (you can leave the AC compressor in the car if you want to avoid evacuating the system).
Step 5: Fuel and Exhaust
- Use a fuel line quick disconnect tool to detach the fuel line at the rear rail.
- Remove the exhaust downpipe bolts at the rear of the engine near the firewall.
- Unbolt the rear exhaust manifold if needed for clearance.
Step 6: Transmission and Suspension
- Disconnect the shift cable and transmission range sensor harness.
- Remove both axles (remove 36mm axle nut, drop lower control arms or remove strut bolts, then pull axles from the transmission).
- Unbolt the torque strut mount near the radiator support.
- Support the transmission with a jack.
Step 7: Engine Mounts
- Unbolt the front and rear engine mounts from the subframe.
- Remove the upper engine mount near the passenger fender.
- Check for any ground straps still connected.
Step 8: Lifting the Engine
- Connect chains or straps to the lift brackets on the cylinder heads or intake manifold.
- Begin lifting slowly while guiding the engine up and forward.
- Watch for any wiring or hoses still connected — double-check before committing to the pull.
Tips:
- Leave the transmission attached if you have room — it simplifies reinstallation.
- If you're separating the engine and trans, remove the flexplate bolts through the access cover on the bellhousing.
- Label everything. The G6 LY7 wiring harness includes multiple cam/crank/VVT connectors – label carefully.
- Use a tarp or cardboard to catch drips and protect your floor.
Optional: Drop Subframe Method
For shop environments, you can drop the entire engine and trans out the bottom:- Support the engine and trans with a rolling cradle.
Reinstallation Notes:
- Replace any damaged or corroded engine mounts.
- Refill fluids after everything is installed and hoses are connected.
- Torque everything to spec, especially axle nuts and suspension bolts.
- Bleed coolant thoroughly to avoid overheating.
