Engine Removal Guide: Pontiac G6 with 3.6L V6 (LY7)
How-To Engine Removal Guide: Pontiac G6 with 3.6L V6 (LY7)
Applies to: 2007–2009 Pontiac G6 GXP with 3.6L LY7 V6 (FWD automatic)
Difficulty: Intermediate – Requires basic tools, jack stands, engine hoist, and mechanical experience
Estimated Time: 6–10 hours depending on experience and rust
Tools & Equipment:​
  • Engine hoist (2-ton recommended)
  • Basic hand tools (metric sockets, extensions, swivels)
  • Jack and jack stands
  • Wheel chocks
  • Screwdrivers, pliers, fuel line quick disconnect tool
  • Drain pans
  • Ziplock bags & labels for bolts
  • PB Blaster / rust penetrant
  • Torque wrench for reassembly
Step 1: Prep Work​
  • Disconnect the battery – Always start here. Negative terminal first.
  • Set the car on jack stands – Securely lift the front of the car and support it under the subframe.
  • Remove the front wheels – Gives access to the axles and lower components.
Step 2: Drain Fluids​
  • Engine oil
  • Coolant – Open the radiator drain plug or pull the lower hose.
  • Transmission fluid – Remove the cooler lines or allow it to drain once axles are removed.
Step 3: Intake and Front End Disassembly​
  • Remove the engine cover, MAF sensor, airbox, and intake tubing.
  • Disconnect the MAF sensor, PCV hose, and throttle body and camshaft sensor wiring.
  • Remove the coolant reservoir and move it out of the way.
  • Disconnect the upper radiator hose and heater core hoses at the firewall.
  • Disconnect radiator fan wiring and remove the radiator fan assembly (2 bolts at top).
  • Optionally remove the radiator for more clearance.
Step 4: Electrical Connections​
  • Label and disconnect all engine harness plugs – injectors, coil packs, O2 sensors, VVT solenoids, etc.
  • Disconnect the engine-to-chassis grounds.
  • Unplug the alternator, starter, and AC compressor (you can leave the AC compressor in the car if you want to avoid evacuating the system).
Step 5: Fuel and Exhaust​
  • Use a fuel line quick disconnect tool to detach the fuel line at the rear rail.
  • Remove the exhaust downpipe bolts at the rear of the engine near the firewall.
  • Unbolt the rear exhaust manifold if needed for clearance.
Step 6: Transmission and Suspension​
  • Disconnect the shift cable and transmission range sensor harness.
  • Remove both axles (remove 36mm axle nut, drop lower control arms or remove strut bolts, then pull axles from the transmission).
  • Unbolt the torque strut mount near the radiator support.
  • Support the transmission with a jack.
Step 7: Engine Mounts​
  • Unbolt the front and rear engine mounts from the subframe.
  • Remove the upper engine mount near the passenger fender.
  • Check for any ground straps still connected.
Step 8: Lifting the Engine​
  • Connect chains or straps to the lift brackets on the cylinder heads or intake manifold.
  • Begin lifting slowly while guiding the engine up and forward.
  • Watch for any wiring or hoses still connected — double-check before committing to the pull.
Tips:​
  • Leave the transmission attached if you have room — it simplifies reinstallation.
  • If you're separating the engine and trans, remove the flexplate bolts through the access cover on the bellhousing.
  • Label everything. The G6 LY7 wiring harness includes multiple cam/crank/VVT connectors – label carefully.
  • Use a tarp or cardboard to catch drips and protect your floor.
Optional: Drop Subframe Method​
For shop environments, you can drop the entire engine and trans out the bottom:
- Support the engine and trans with a rolling cradle.
- Unbolt the entire front subframe assembly and lift the body upward with a hoist.
This method is faster but requires overhead lift equipment.
Reinstallation Notes:​
  • Replace any damaged or corroded engine mounts.
  • Refill fluids after everything is installed and hoses are connected.
  • Torque everything to spec, especially axle nuts and suspension bolts.
  • Bleed coolant thoroughly to avoid overheating.
Pontiac G6 3.6L LY7 Engine Removal – Tips & Tricks
Applies to: 2007–2009 Pontiac G6 GXP with 3.6L LY7 V6 (FWD)
General Tips:​
  • Label every electrical connector and vacuum hose. LY7 engines have multiple VVT solenoids, cam sensors, and coil connectors that look similar.
  • Take photos before you start. Especially around the throttle body, fuel rail, and rear bank – it helps a lot during reinstallation.
  • Remove the hood for better overhead access. Mark the hinge positions first to simplify re-alignment.
  • Penetrating oil (PB Blaster or equivalent) the night before on exhaust bolts, engine mounts, and axle nuts saves major time and broken tools.
  • Have extra hose clamps and zip ties on hand. You’ll likely need them during reinstallation for old brittle clamps.
Engine Hoisting Tips:​
  • Use proper lift brackets or heavy-duty straps bolted to the heads or upper intake. The LY7 doesn’t always have obvious lift points.
  • Lift the engine and trans together if possible – separating them adds time and increases the chance of damage to the flexplate or torque converter.
  • Tilt the assembly slightly toward the transmission side while lifting to help clear the firewall and subframe.
  • Watch the power steering lines – they tend to snag under the rear cylinder bank. Unbolt or bend brackets gently for clearance.
Subframe/Exhaust Tricks:​
  • You don’t need to fully drop the subframe, but loosening it slightly at the rear can provide more engine clearance for hoisting.
  • Unbolt the rear exhaust manifold heat shield for more room behind the engine.
  • Removing the catalytic converter helps with exhaust flex and reduces pressure on the rear downpipe bolts.
Reassembly Notes:​
  • Clean all mating surfaces – especially the engine mounts and ground strap locations. Poor grounds cause many weird electrical issues.
  • Replace old heater core hoses and clamps while you have access. The rear bank firewall area is nearly impossible to reach with the engine installed.
  • Top off and bleed the cooling system with the front of the car raised to help release air pockets from the rear bank.
