- 139
Front Brake Upgrades
F-Body Dual-Piston Swap
- Parts: 1998–2002 Camaro/Firebird calipers, brackets, pads, and 12-inch rotors.
- Why: Affordable and reliable performance boost.
- Wheel Fitment: Compatible with most factory 16-inch wheels.
Grand Prix GXP 12.7-Inch Upgrade (ATS/GXP Hybrid)
- Parts: Cadillac ATS Brembo calipers, GXP brackets, GXP 12.7-inch rotors, ATS pads.
- Why: Large rotors with Brembo stopping power.
- Wheel Fitment: Requires 17-inch or larger wheels with adequate caliper-to-wheel clearance.
Grand Prix GXP OEM Upgrade
- Parts: GXP dual-piston calipers, brackets, 12.7-inch rotors, and pads.
- Why: Bolt-on simplicity with solid performance.
- Wheel Fitment: Requires 17-inch wheels or larger.
CTS-V Gen 1 14-Inch Big Brake Kit
- Parts: CTS-V Gen 1 calipers, brackets, 14-inch rotors, adapter bracket, custom brake lines, GT500 rotors.
- Why: Huge upgrade for stopping power and heat resistance.
- Wheel Fitment: Requires 18-inch wheels with sufficient caliper-to-wheel clearance.
- How to: LINK
CTS-V Gen 2 15-Inch Big Brake Kit
- Parts: CTS-V Gen 2 Brembo 6-piston calipers, 15-inch rotors, adapter bracket, custom brake lines.
- Why: Extreme stopping power and modern performance for high-performance builds.
- Wheel Fitment: Requires 19-inch wheels (or some 18-inch wheels) with plenty of caliper-to-wheel clearance.
Rear Brake Upgrades
CTS-V Rear Brake Swap
- Parts: CTS-V Brembo calipers, larger rotors (up to 14 inches), adapter bracket, custom brake lines.
- Why: Matches front CTS-V setup for balanced braking performance.
- Wheel Fitment: Requires 18-inch wheels or larger with sufficient caliper-to-wheel clearance.
Grand Prix GXP Rear Upgrade
- Parts: GXP rear dual-piston calipers, brackets, larger rotors (11.7 inches).
- Why: Improved rear stopping power, balances upgraded fronts.
- Wheel Fitment: Compatible with 17-inch wheels or larger.
Brake Lines
Braided Stainless Steel Lines
- Parts: Russell, StopTech, or Goodridge stainless lines (front and rear).
- Why: Firmer pedal feel, reduced expansion under pressure.
Brake Fluid
Recommendations
- DOT 3: Stock replacement.
- DOT 4: High-performance and everyday use.
- DOT 5.1: Higher boiling point for enhanced performance on the street.
Brands
- Castrol Brake Fluid (DOT 3, DOT 4)
- Valvoline SynPower Brake Fluid (DOT 3, DOT 4)
- Prestone DOT 3 Brake Fluid
- ATE Typ 200 (DOT 4)
- Royal Purple Brake Fluid (DOT 4)
- Mobil 1 Synthetic Brake Fluid (DOT 3 & 4)
- AMSOIL Synthetic Brake Fluid (DOT 3 & 4)
- Bosch ESI6 (DOT 3,4,5.1 Compatible)
Flush Frequency
- Every 2–3 years or annually for high-mileage vehicles.
Tips
- Master Cylinder: Ensure it can handle larger calipers.
- Wheel Clearance: Most brake kits (besides F-body) require 17, 18, or 19-inch wheels with adequate caliper-to-wheel clearance. Check specs before purchasing.
Disclaimer: Some Gen 3 W-body vehicles may require modifications to the e-brake mechanism when upgrading the rear brakes.
Brake upgrade page: LINK
Post your setups and results below!
