- Dec 14, 2024
- 20
Hello! New to forum, not to platform. Heres my 02 Monte with a 62mm turbo on slicks!
Very very cool! would love to see more of this! Makes me excited to build my shitcarlo v2 next year!Hello! New to forum, not to platform. Heres my 02 Monte with a 62mm turbo on slicks!
Started life as a 2002 SS N/A 3.8l. Ive stripped it down to dash and head liner and got the weight down to 3k. The motor has not been opened since ive replaced the heads 4 years ago. It has zzp's z3 turbo kit with a 2.5" exhaust that dumps right behind the passenger side seat. So far ran a 8.15 to the 1/8th and a 12.71 to the 1/4.Welcome to WBT and Dude that's a sick build. I'd love to know more about it. Feel free to browse the forums and post around, we are open to any forum suggestions as well.
That's pretty damn impressive, especially in the 1/4 mile.Started life as a 2002 SS N/A 3.8l. Ive stripped it down to dash and head liner and got the weight down to 3k. The motor has not been opened since ive replaced the heads 4 years ago. It has zzp's z3 turbo kit with a 2.5" exhaust that dumps right behind the passenger side seat. So far ran a 8.15 to the 1/8th and a 12.71 to the 1/4.
In all seriousness, ill be going for 11's next time I go out to run. Hopefully will be about 200lbs lighter to get that low 12s or high 11sThat's pretty damn impressive, especially in the 1/4 mile.
Seeing these old cars in the 11s is always pretty cool.In all seriousness, ill be going for 11's next time I go out to run. Hopefully will be about 200lbs lighter to get that low 12s or high 11s
you need to learn to drive the bonny first lol.Welcome to the forum!
This is sexy asf! Very nice to see this! Wish i had a turbo and big meats on my bonnie. (Maybe one day)
All there is to it is to do it!Welcome to the forum!
Ive learned a lot since the time i almost killed youyou need to learn to drive the bonny first lol.
Yes I am! Currently holding power at 10 psi of boost. Gonna be upgrading the upper intake manifold to the series 3 aluminum one soon. Any info on that swap would be appreciated, what I have Currently is aluminum series 3 plenum with a adapter from the drive by wire to drive by cable and ill be completing it with a l67 TBLove it!! Are you pushing that through a stock 4T65E??
Should upgrade to the northstar throttle body and lq4 maf while you’re there. Throttle response increases dramatically with the northstar throttle body.Yes I am! Currently holding power at 10 psi of boost. Gonna be upgrading the upper intake manifold to the series 3 aluminum one soon. Any info on that swap would be appreciated, what I have Currently is aluminum series 3 plenum with a adapter from the drive by wire to drive by cable and ill be completing it with a l67 TB
Ive heard good and bad about the N*. Im interested in the lq4 but im using my spare change to build this car. Once something goes, and it will, I'll take my time building it again and doing it in a way to make everyone scratch their heads.Should upgrade to the northstar throttle body and lq4 maf while you’re there. Throttle response increases dramatically with the northstar throttle body.
Ive been looking at that. Im gonna have to change my intercooler piping around to fit, maybe even shorten it a few inches. We will see how that goes soon.I've done the opposite, actually!I swapped in a Series III engine into a 1998 Regal in place of an S2, and installed the S2 UIM and injectors onto the S3 engine. I found that everything on the S2 and S3 are 100% interchangeable. The length of the S3 UIM plus the TB adapter will push ever so near to the strut tower..
I did this to a 04 Impala. Removed the series 2 and dropped in my series 3 lol. It's all interchangeable, I'm currently building s NA series 2 with a series 3 top end for my Park Ave.I've done the opposite, actually!I swapped in a Series III engine into a 1998 Regal in place of an S2, and installed the S2 UIM and injectors onto the S3 engine. I found that everything on the S2 and S3 are 100% interchangeable. The length of the S3 UIM plus the TB adapter will push ever so near to the strut tower..
New guy!
New here
Long time W-Body owner, new member to this forum saying "HI"
hello all forum members!
