- 313
This suspension upgrade list applies to the following Gen 1.0 & 1.5 W-Body vehicles
This thread is dedicated to listing all available W-Body suspension upgrade parts in one convenient location. Whether you’re looking to improve your handling or refresh your worn-out suspension, this list provides part numbers and compatibility information for easy reference.
Front Struts: (These are a welded assembly and can be modded)
Rear Struts: (Only available on the 1995-2001 1.5 Gen Platform 1995-1999 Monte Carlo, 1995-2001 Lumina)
Front Lowering Springs:
Intrax Suspension Coil Springs (1.8" drop) 25-1-024
Rear Monoleaf options:
Control Arm Bushings:
Front Sway Bars:
Rear Sway Bars (Stock is 12-14mm):
Sway Bar bushings:
Trailing Arms:
Lateral Arms:
Roll Cage Kit:
- 1988–1996 Buick Regal
- 1988–1997 Oldsmobile Cutlass Supreme
- 1988–1996 Pontiac Grand Prix
- 1990–2001 Chevrolet Lumina
- 1995–1999 Chevrolet Monte Carlo
- Parts list coming soon.
- There aren't any options to buy a mono leaf these days, there were lowering ones back in the day.
- Birchmount Auto Spring Company
- 458 Birchmount Road
Scarborough, ON
P/N M1K1M6
Telephone: (416) 698-3636
Fax: (416) 698-5732
- Energy Suspension polyurethane front control arm bushings 3.3171R
- Energy Suspension polyurethane front control arm bushings 3.3171G
- (requires modification to fit)
Front Sway Bars:
- GM 34mm Sway Bar #26024362
- Compatibility: Fits all 1st Gen W-body vehicles 1988-2001
- Addco 7/8” Rear Sway Bar Part #474
- Compatibility: Fits all 1st Gen W-body vehicles except the 1995-2001 Monte Carlo and Lumina.
- Addco 7/8” Rear Sway Bar Part #639
- Compatibility: Specifically for 1995-2001 Monte Carlo and Lumina.
Sway Bar bushings:
- (34mm bar) inner: MOOG Part # K6457 {Sway Bar Bushing Kit} Front Suspension; To Frame; w/1-5/16" Bar
- (all bars) outer: MOOG Part # K6641 {Sway Bar Bushing Kit} Front Suspension; To Control Arm
Trailing Arms:
- Dorman trailing arm replacements (square tube) 905-501
- GM Tubular Trailing Arms #12498649 (Discontinued)
- BMR Trailing Arms with Polyurethane Bushings TCA011
- Description: Sold as a pair, complete with bushings.
- Compatibility: Fits 1st, 2nd, and 3rd Gen W-body vehicles.
Lateral Arms:
Roll Cage Kit:
- Part Number: 550-946805K (Discontinued)
