ThatSlow.W204
Social Media Manager
If you're looking to enhance the handling, stability, and overall performance of your W-Body vehicle, a suspension upgrade is one of the most impactful areas to focus on. Here's a detailed guide covering all the key components you should consider for your Gen 2 or Gen 3 W-Body car:
1. Strut Tower Braces
Strut tower braces improve chassis rigidity by reducing flex between the strut towers. This upgrade enhances cornering performance and overall steering response.
2. Tubular Control Arms
Tubular control arms reduce weight and improve suspension geometry for better handling. They also enhance durability compared to factory arms.
3. Polyurethane Bushings
Replacing stock rubber bushings with polyurethane improves suspension response, reduces flex, and enhances durability.
  • Complete Poly Bushing Kits:
    • Link: LINK N/A
4. Sway Bars
Upgrading your sway bars reduces body roll during cornering, improving overall handling and driver confidence.
5. Sway Bar End Links
Performance sway bar end links ensure proper sway bar function and enhance stability.
6. Solid Subframe Bushings
Solid subframe bushings eliminate unnecessary movement of the subframe, allowing for more predictable suspension behavior.
7. Coilovers
Coilovers offer adjustable ride height and damping, allowing you to fine-tune your car's suspension to your driving style and road conditions.
Additional Upgrades
  • Performance Shocks and Struts: To complement the new suspension setup if you don't do coil overs.
  • Alignment Adjustments: After completing these upgrades, invest in a professional alignment for optimal performance.
  • Brake Upgrades: Since you'll be cornering faster and harder, upgrading your braking system is a great complement to these mods. - separate thread will be made.
Conclusion
With these suspension modifications, your W-Body will handle like never before. Whether you're chasing lap times or enjoying spirited driving, these upgrades are sure to bring out the best in your car. Have fun wrenching, and feel free to share your setup and results!
Happy modding! 🚗💨
    • Link: LINK N/A
4. Sway Bars
7. Coilovers
Additional Upgrades
Conclusion
Happy modding! 🚗💨
What about with police/taxi models? I’ve got an 06 9c1 police and want to get coilovers for it but every website says they aren’t compatible with police/taxi models. I also bought some 2006 SS wheels and they fit fine in the front but don’t clear the spring in the rear, which is why I’m even looking for coils at all
Most police package cars came equipped with iron knuckles instead of aluminum to enhance durability, especially during pursuits and high-stress driving situations. The taxi packages received the same components since GM didn’t see the need to engineer a separate setup for taxis. Structurally, everything bolts up the same, making them interchangeable. I daily drove a 13’ impala 9c1 for a bit and did a bunch of work to it, got to learn a bunch about em at the time. Also, forgot to mention. the rear wheels not fitting is pretty normal, for some reason the hat that the spring sits in to was different based on the suspension RPO code, FE1,FE2,FE3,FE4, I don’t know why but it’s just the way it is, the coil-overs will bolt together to your knuckle and the strut tower just fine though.
Thanks boss, saving me a huge worry here just didn’t wanna waste a thousand bucks on BC’s if they wouldn’t work, not sure why the websites state that they don’t work for those packages but thank you again! Really appreciate it. Kinda goes without saying then that if I put coilovers on my wheels will fit then?😂
Similar threads Most view View more
