- 138
many of you may know about this, although some might not know, about a few years ago i decided to LFX/6t70e swap my 2003 monte carlo i had. i used a 2013 impala lt as the donor vehicle, the engine (LFX) is a 3.6 liter v6, many hate on the 3.6L but they do not realize that the LFX came out and fixed almost every single issue the older 3.6 had (ly7, ltt) timing chains being the big one everybody hates the 3.6 for, the lfx is a great powerplant because from factory it makes 300 horsepower n/a, is lighter than the 3800 being all aluminum, and can be modified to great power numbers with not to many mods (350+ crank horsepower is very possible with simple mods like intake, e85, new catless downpipes, tune, intake plenum spacers, and a set of cams.) the transmission (6t70e) is great because you get two extra gears in a transmission much stronger the the 4t65e while being smaller. i swapped almost everything from the impala to the monte carlo and almost every single thing was a direct bolt in! (engine, trans, subframe, fuel tank, all fuel lines and brake lines, wiring, fuse blocks, entire dash assembly and interior wiring, and much more!) if anyone has any more questions i can answer them most likely, main reason i got rid of the car was body was rough and starting to develop serious rust. will include some pictures that i may still have
