Long time no see, and Merry Christmas Everyone!!
Sorry for being away for so long, Thanksgiving break came to an end and finals came, kicked my *ss, and went. BUT that means the semester came to an end and I had ~ a month off from school to dump into the project. I'm oil stained, sore, and have a permanent odor of coolant about me, but now I have something killer to show off.
At long last, after an entire year of slowly working towards this project, the mechanical aspect has finally come to a close. Getting that broken head bolt out was a massive pain in the ass, but with some magic and luck it worked its way right out.
I would like to STRESS the importance of either buying torque wrenches new, or at the very least using one that's verified good. Skip out on any rentals ESPECIALLY one rented from a certain autoparts store. *cough cough, AUTOZONE
, cough cough*
Deciding that money is no longer of any object I decided to forego TTY silliness and ball out on some of ZZP's re-usable head studs. From the way they were packaged, to the weight of them in hand they felt like serious pieces of hardware. Quickly note that ZZP recommends thouroughly cleaning and chasing the bolt holes and added 4-5 wraps teflon tape as the bolt holes go into coolant jackets. Graphite gaskets (
as recommended by WBT) were used here bc I didn't feel like shelling out for MLS.
Followed up with the (
ALUMINUM lower intake gaskets and generous dabs of RTV in each corner. Plastic ones are known to go bad, and RTV helps to seal the corners. Decided to up torque to 15ft/lbs with the aluminum gaskets. ZZP's reuseable rocker bolts, while not well-pictured, are used as well. IIRC 23ft/lbs and red loctite.
A well-cleaned LIM and freshly painted supercharger complete our yummy 3800 sandwhich. Again, (
as recommended by WBT) aluminum SC gaskets are used.
Finishing up the other stuff, SC harmonic balancer, idler pulleys, tensioner pulley, and dogbone bracket/ICM bracket are all added. Boost bypass solenoid is removed due to not having the connector for it, and since my NA harness only has one connector for a MAP sensor I've got a short run of rubber tubing connecting the SC one to the little connector on the LIM. I'm assuming some wiring stuff and vacuum stuff here is probably wrong, so I'll sort that all out as we go!
Once again, Merry Christmas to all, and let's hope for some more Christmas magic as I move onto tuning and wiring here!
