- 313
1988-2016 W-Body Radiator & Cooling System Guide
W-BodyTech radiator guide into a full platform-wide cooling system reference for 1988-2016 GM W-Body vehicles.
The original guide and video focused on a later Pontiac Grand Prix, but the new guide has been rebuilt to cover the entire W-Body platform, all major generations and the different engine families used throughout production.
W-BodyTech Radiator Replacement Video
The video below shows the hands-on radiator replacement process and is a useful visual reference to use alongside the expanded written guide.
Vehicles Covered
Engine Families Covered
What the Guide Covers
Read the Full Guide
W-Body Radiator & Cooling System Guide: 1988-2016
Help Build the W-Body Cooling System Database
I’d like this thread to become the community reference for radiator fitment and cooling-system information across the entire W-Body platform.
If you’ve replaced a radiator or worked through a cooling-system problem on your W-Body, post as much of the following information as you can:
Corrections & Additional Information
W-Bodies span nearly three decades, several chassis revisions and many different engine families. There are differences in radiator dimensions, hose routing, transmission cooler connections, fan assemblies, pressure-cap locations and coolant bleeding procedures.
If your car uses a setup that isn’t documented correctly in the guide, post the details here.
The same goes for:
The goal is to build a verified radiator and cooling-system reference for every W-Body generation, model and engine family.
Vehicles Covered
- Buick Regal
- Buick Century
- Buick LaCrosse / Allure
- Chevrolet Lumina
- Chevrolet Monte Carlo
- Chevrolet Impala
- Chevrolet Impala Limited
- Oldsmobile Cutlass Supreme
- Oldsmobile Intrigue
- Pontiac Grand Prix
- Early W-Body four-cylinder applications
- 2.8L / 3.1L 60-degree V6
- 3100 / 3400 V6
- 3.4L DOHC LQ1
- 3800 Series II L36 / L67
- 3800 Series III L26 / L32
- 3.5L LX5 Shortstar
- 3.5L / 3.9L High Value V6
- 3.6L High Feature V6
- 5.3L LS4 V8
- Radiator replacement
- W1, W2 and W3 cooling-system differences
- Radiator selection and fitment
- Upper and lower radiator hoses
- Thermostats and seals
- Radiator and surge-tank pressure caps
- Transmission cooler-line service
- Cooling fan and shroud removal
- A/C condenser separation
- Coolant selection
- Engine-family-specific fill and bleed differences
- Overheating diagnosis
- Cooling fan diagnosis
- Post-installation checks
- Parts-selection guidance
Read the Full Guide
- Year:
- Make / Model:
- Engine:
- Transmission:
- Radiator Brand:
- Radiator Part Number:
- Transmission Cooler Fitting Type:
- Upper / Lower Hose Part Numbers:
- Thermostat Used:
- Coolant Used:
- Fill / Bleed Procedure:
- Fitment Issues:
- Anything You Would Do Differently:
- Photos:
The same goes for:
- Confirmed radiator part numbers
- Radiator brands that fit particularly well or poorly
- Different transmission cooler fittings
- Engine-specific bleed screw locations
- Cooling fan differences
- Heavy-duty or performance cooling packages
- Model-year changes
- Factory service information that improves the guide
