- 313
Turbo Grand Prix Drivability Reference: Stalling, Vacuum Leaks & TopGun Chip Notes
This reference organizes the useful maintenance and troubleshooting information from JeffM_TG160180 Document.pdf, titled Installation, Operation and Troubleshooting Instructions, Ver. 2.5: Driveability/Performance Series and TopGun 180-160 Performance chip for the TGP, dated July 21, 2004.
Thanks to Chris DiNunzio from the McLaren Grand Prix Facebook group for sharing this document with the community.
The main takeaway: Get the engine running correctly before expecting a performance chip to help. The original guide specifically calls out exhaust leaks, vacuum leaks, ignition maintenance, PCV problems, a dirty throttle body/IAC, and fuel-system faults.
This is an edited reference, not a verbatim transcription or a factory service procedure. Part numbers and calibration recommendations below are historical information from the document; current replacements and compatibility have not been verified. Page numbers refer to the original PDF.
1. Start with the symptom
2. Crossover leaks: why they can look like a fueling problem
The guide describes how a crack or other exhaust leak upstream of the oxygen sensor can admit outside air between exhaust pulses. The sensor can then report an apparent lean condition, prompting the ECM to add fuel even though the engine does not need it.
The resulting rich operation can contribute to stalling and poor fuel economy. The document also warns about fuel dilution of the engine oil and associates a cracked crossover with elevated Integrator and BLM readings.
Practical use: Include the crossover and upstream exhaust joints in a rich-running or stalling diagnosis. Replacing the O2 sensor alone does not repair an exhaust leak. Pages 2, 4-5.
3. TGP vacuum-leak inspection map
Use this as a location checklist. Confirm routing against the correct vehicle diagram before changing or capping any line. Page 3.
4. Idle-quality details worth remembering
PCV valve
The PCV is in the center of the rear rocker cover near the firewall. The guide warns that pulling aggressively can disconnect its hose underneath the upper intake, creating a much larger access job. Inspect the valve, grommet, and hose without tugging on the hidden connection. Page 4.
Idle air control (IAC)
The guide identifies the IAC by its four-wire connector at the throttle body. Deposits on the pintle and in its passage can interfere with idle control. It also warns about brittle connector tabs and disturbing the pintle position. Use the applicable service procedure and a compatible cleaning method. Page 4.
Throttle body and charge-pipe connection
The document calls attention to deposits on both sides of the throttle plate and inside the bore. During reassembly, confirm that the coupling fully surrounds the throttle-body opening before securing it. Inspect the underside rather than relying only on the visible top edge. Page 6.
5. Original parts and numbers
Archive lookup list: verify present-day fitment and supersessions before ordering.
6. Scan-data clues from the original guide
For O2 evaluation, the author describes a signal moving approximately 100-800 mV at 1,200-1,500 rpm and approximately two cross-counts per second. The guide also points to high Integrator/BLM values when discussing crossover leaks.
These are the author's diagnostic observations, not a complete pass/fail test. Record operating conditions and interpret the readings with the applicable service information. A single reading does not establish the cause. Pages 4-5.
7. TopGun chip and thermostat archive notes
The following details belong to the specific chip packages discussed in this document.
Identify the installed calibration before applying these notes. Use the full instructions for that calibration and the vehicle service procedure. Repeated stalling should be diagnosed rather than dismissed as normal learning. The original document labels the chip for off-road use only. Pages 5, 7-9.
8. Reading this 2004 guide today
The troubleshooting locations remain useful as an inspection checklist, but several service methods need separate verification. Follow the current plug manufacturer's instructions for thread treatment and torque; use the proper fuel-pressure relief procedure before opening the fuel system; and follow the vehicle's cooling-system filling and bleeding procedure. Do not assume an overnight wait eliminates fuel pressure or that a stated retained-water amount guarantees the coolant mixture.
The guide's old prices, rebate offer, future-product announcements, brand comparisons, and performance claims are not current purchasing advice. This reference preserves the technical leads without treating those claims as independently verified results.
9. What to include when asking for help
For a more useful troubleshooting reply, include:
Source page index
Source credit: JeffM_TG160180 Document.pdf, Ver. 2.5, dated 07/21/04. Consult the original PDF for the complete wording and context. Confirmed corrections, replacement part numbers, and clear photos of the vacuum-line locations would be useful additions to this thread.
- Stalling or unstable idle: Inspect the crossover and other exhaust joints ahead of the oxygen sensor, vacuum plumbing, PCV valve, throttle body, and idle air control (IAC). The guide also lists leaking injectors and a failed stop-lamp switch among possible causes. Pages 2-4, 6.
- Rich running or poor fuel economy: Investigate exhaust leaks ahead of the O2 sensor and review sensor activity and fuel-trim data. Do not assume the sensor itself is the original fault. Pages 2, 4-5.
- Harsh engagement into Drive/Reverse or harsh downshifts: Inspect the transmission-related vacuum check valve below the turbo, near the front of the transmission case. Treat this as a diagnostic lead, not proof that the valve is the only possible cause. Page 3.
- HVAC air comes from the wrong outlets: Inspect the vacuum supply, tees, reservoir connection, and lines feeding the HVAC system. Page 3.
- Loss of power after throttle-body or intake-pipe work: Recheck the hose connection all the way around the throttle body, especially underneath. The guide warns that the hose can fold against the opening instead of slipping over it. Page 6.
- Below the turbo / front of the transmission case: Locate the tee-shaped vacuum check valve. Inspect the valve, connections, and hose routing. The guide names GM 14056648 as the replacement it had identified at the time.
- Under the cruise-control unit: Follow the small hard plastic vacuum line down to the rubber tee. The guide highlights this tee as an age- and heat-related failure point.
- Around and below the washer bottle: Follow the line toward the front fender and vacuum reservoir ball. Check the connection gently; the reservoir fitting can break.
- Top of the throttle body: Inspect the rubber connector carrying four hard plastic lines. Follow each line and check for cracks, melting, pinches, loose ends, and damaged rubber connectors.
- Fuel-pressure regulator and MAP sensor branch: The document identifies a line running to the regulator and continuing to the MAP sensor behind the upper intake. Pay particular attention to this branch.
- Other branches: Inspect the vapor-purge, EGR, cruise-control, and HVAC supply plumbing, including the hidden tee behind and somewhat below the engine.
PCV valve
- Spark plug: AC R42LTS. The guide specifies a 0.040-inch gap for its application, reduced from the 0.045-inch setting it describes. Page 1.
- Other plugs mentioned: Denso IT20 and NGK TR5-IX. These are the identifiers as printed in the document. Page 1.
- Fuel filter: AC Delco GF-481, GM 25055052. The author explicitly distinguishes it from GF-483. The guide recommends a 30,000-mile replacement interval. Page 2.
- Vacuum check valve: GM 14056648. Page 3.
- Oxygen sensor: AC Delco AFS-22. Page 5.
- Air filter for the described Performance/TopGun setup: K&N RU1390. The guide presents this as a requirement of those chip packages. Page 2.
- Breathers mentioned for that intake conversion: K&N 62-1010 and 62-1100. These belong to the guide's modified intake arrangement, not a universal stock-maintenance requirement. Page 2.
- Thermostat: Page 5 discusses a custom 160-degree thermostat. It lists stock fan-on points of 215°F for Fan 1 and 219°F for Fan 2. It does not supply a complete set of replacement fan thresholds for every chip version.
- MEMCAL installation: Page 7 describes access to the ECM at the passenger-side wheel well and removal of the yellow 20-amp FUEL PUMP-ECM fuse before the swap. It emphasizes preserving MEMCAL orientation and seating both ends evenly.
- Cover pad: The author warns that a cork block under the access cover can press on the MEMCAL and recommends removing it. This is the document's guidance; a supporting GM bulletin is not included in the PDF.
- Learning sequence: Page 8 describes alternating approximately one minute at 1,200 rpm with one minute at idle after a cold start begins warming, continuing until the fan operates, allowing it to cycle off, then shutting down for about 15 seconds. The author then repeats the idle/rev sequence after restart until the fan comes on again and advises avoiding heavy boost for a few days.
- Model year and installed chip/calibration, if known.
- Intake, thermostat, injector, turbo, and other relevant changes.
- Whether the problem happens cold, warm, at idle, on deceleration, or under load.
- Stored trouble codes and available scan data, with operating conditions.
- What has actually been inspected or tested, including crossover leaks and vacuum plumbing.
- Recent repairs and whether the symptom started immediately afterward.
Source page index
- 1: Introduction and spark plugs.
- 2: Air filter, fuel filter, stalling, and crossover explanation.
- 3: Vacuum leaks and line locations.
- 4: PCV, IAC, and O2 testing discussion.
- 5: O2 continuation and thermostat/cooling procedure.
- 6: Throttle-body cleaning and intake-hose fitment.
- 7: Chip/MEMCAL installation.
- 8: Learning sequence and historical sales/update information.
- 9: Original disclaimer and off-road-use statement.
