- Sep 29, 2024
- 92
2000 F.1 GTX (AKA) The Last Indian. Because the MS2000 platform was the very last American built, designed & engineered Pontiac!
SignUp Now!Attachments
Love the car, did you make that lip yourself?2000 F.1 GTX (AKA) The Last Indian. Because the MS2000 platform was the very last American built, designed & engineered Pontiac!
I assume you mean the lower splitter? Yes, among many many other things with the car. Suspension, engine, interior, structural things as well as other exterior body appearance pieces. Car only has 39,000 + summer only miles on it.Love the car, did you make that lip yourself?
Welcome2000 F.1 GTX (AKA) The Last Indian. Because the MS2000 platform was the very last American built, designed & engineered Pontiac!
Thank You! Good to be here.Welcome
Well that would be a lengthy answer. The original SD air dam is made to over lap the cover on the inside face of cover at the wheel well. It also had a much lower projection in the front at the bottom, neither of which did I want. So in the pictures you will see that the portion of the dam that would over lap the cover in the wheel well area is cut away & the bottom lower lip of the dam is reduced by 2”. The air dam is not glued or cemented. It is attached through an array of very thin aluminum brackets I made that rivet to both the cover & the air dam. Those areas are countersunk & filled on final completion with body filler. The void space between the two pieces is filled with polyurethane foam, which gives the whole unit great one piece rigidity.That looks fantastic! I like how you made it all one piece, it gives it such a clean, seamless look. Did you use plastic cement or fiberglass for the build?
Thank you for sharing these! They’ll be really helpful for anyone looking to make similar modifications to their vehicle. Would you mind if we feature this information on our main website once the modification pages are live? We would link it back to this post.So, below are some pictures that indicate the attachment manner of the air dam.
Killer lookin car, that F.1 kit must be super rare bc you're the only other person I've seen with it. Welcome to the forums2000 F.1 GTX (AKA) The Last Indian. Because the MS2000 platform was the very last American built, designed & engineered Pontiac!
No I don’t mind at all. There is actually quite a bit more to this whole front cover build hat I will try to detail as I have a chance.Thank you for sharing these! They’ll be really helpful for anyone looking to make similar modifications to their vehicle. Would you mind if we feature this information on our main website once the modification pages are live? We would link it back to this post.
It's a replica with mirrored colors. The other one is from NY, the guy moved to FL and parted out his car so I got his good and wing.I think Rob's gold car is the F1
I actually would like to know more about your build, I don't think anyone here is gonna call it BS.Ok before I go further let me clarify. The Last Indian is not an official F.1 or Gtx. The F.1 was a sanctioned Pontiac dealer authorized aftermarket option done by MPD inc operated by Eric Peters, now out of business. And The GTX option was the same type deal with SLP. I knew Eric & we talk many times, & while I liked some of the upgrades he added to the GP there were others I didn’t want. The same held true for SLP’s & their upgrades. So other than the MPD F.1 hood all the changes are my designs. I use the designation F.1 & GTX because the F.1 designation is used for Ram Air & the GTX designation is used for experimental, both of which much of this car is!
Now to clarify that a little more I will say this. I knew exactly what & how to make the changes that needed to be made to create a intimidating ground pounder in the vein of the muscle car era ground pounders. Wheels, engine, transmission, suspension & aesthetics. Removing the mentality of a business to produce multiple pieces, so sacrificing the best way for the smart production way was not my goal. Example, SLP’s air box may function ok, it is better than the factory, but it is far from optimal! My setup, which is rooted in physics law actually is. So you folks might wish for me to continue to detail these. Yet if you believe this to be just BS. Than we’re good as is.
Thanks Reb, I wasn’t saying anyone would, but if there was than ok, I just don’t want to be that guy that starts some big controversy!I actually would like to know more about your build, I don't think anyone here is gonna call it BS.
Some bling for the front cover
