Pontiac G6 GTP F40 Manual Swap: Parts Guide
6 Speed Saab MR6/F40 Pontiac G6 GTP F40 Manual Swap: Parts Guide
Application: Because GM used this pattern for decades across multiple brands, you have a massive list of potential engines that will bolt up to the F40 transmission.
Direct Bolt-On Engines (60° V6 Pattern)​
These engines share the exact same mounting flange. Note that while they bolt up, you may still need to account for flywheel/clutch spacing and starter location.
High Value V6 (Pushrod)​
  • 3.9L (LZ9): The original engine.
  • 3.5L (LX9, LZ4, LZE): Found in G6, Malibu, and Impala.
  • 3.4L (LA1): Found in Grand Am, Alero, and various minivans.
  • 3.1L (L82, LG8): Found in Lumina, Malibu, and Grand Prix.
  • 2.8L (L98): The original 60-degree V6 from the 1980s (Celebrity, Citation).
3800 Series II & III V6 (90° V6)​
  • 3.8L (L36): Naturally aspirated.
  • 3.8L (L67 / L32): Supercharged (GTP, Regal GS, Bonneville SSEi).
High Feature V6 (DOHC)​
  • 3.6L (LY7 / LLT): Used in the G6 GXP and early Camaros/Cadillacs.
  • 2.8L (LP1): Turbo version found in Saab 9-3 Aeros (which also used the F40).
The "Oddballs" & V8s​
  • 5.3L LS4 V8: The only LS-series V8 with this pattern (Found in Impala SS, Monte Carlo SS, Grand Prix GXP). Note: The F40 requires housing clearancing for the LS4 starter.
  • 3.5L LX5 "Shortstar": The DOHC V6 version of the Northstar V8 (Found in Olds Intrigue).
  • 2.2L Ecotec (L61): Some early versions used this pattern, but most use the Ecotec-specific pattern.
  • 2.5L "Iron Duke" I4: Found in S10s and Fieros.
1. Drivetrain & Axles​
The F40 6-speed is a high-torque unit. It requires a specific manual-only "jackshaft" and matching axles.
ComponentGM Part NumberNotes
F40 6-Speed Transmission55562951Option code MU9.
F40 6-Speed Transmission55561229(3.55 Final Drive Ratio)
Intermediate Shaft (Jackshaft)22668353Essential to bridge the block to the pass. axle.
Driver Side CV Axle15918504Manual-specific length.
Passenger Side CV Axle15918505Connects to the jackshaft.
Output Shaft Seals (x2)90354481Recommended new for the swap.
Upper Trans Mount15299173Manual-specific mounting bracket.
2. Clutch & Flywheel​
The 3.9L LZ9 uses a Dual Mass Flywheel (DMF).
Dual Mass Flywheel12586675Specific to the 3.9L crank pattern.
Clutch Kit (Disc/Plate)12586672OEM spec (LuK equivalent: 04-251).
Flywheel Bolts (x8)11588785One-time use (Stretch Bolts).
Pressure Plate Bolts (x6)11561081Recommended new.
3. Shifter & Interior​
The automatic shift assembly must be replaced entirely.
Shifter Assembly15296498Complete manual floor unit.
Shifter Cables15788845Dual cable set.
Shifter Boot / Bezel15277861Replaces the automatic PRNDL trim.
Shifter Knob15281146Original GTP 6-speed knob.
4. Hydraulics & Pedal Assembly​
You will need to drill the firewall indentation to mount the master cylinder.
Pedal Assembly (Brake/Clutch)15274154Combined bracket with both pedals.
Clutch Master Cylinder15275811Mounts to the firewall.
Slave Cylinder (TOB)24240351Concentric unit inside the bellhousing.
Main Clutch Line15275820High-pressure line (Master to Slave).
Reservoir Feed Hose15275813Feeds fluid from the brake reservoir.
