- Sep 14, 2023
- 63
2000 Pontiac Bonneville SSEi in depth build
Link to photo & video album at the bottom of this post
Engine:Link to photo & video album at the bottom of this post
- October, 2022 - March, 2023
- This whole process started in October, 2022. I wrote up a list of modifications to make to my car, I felt it was finally time to start building this car.
- Throughout October, November, and December, I prepped to remove the engine and transmission. The original plan was to just clean up and throw a camshaft and various other valvetrain upgrades onto my car.
- Once the engine was removed and put onto a stand, I soon discovered that this engine was really rough. I was then prompted to find a low mile junkyard motor to use. January, 2023 rolls around and it appears I have found an engine! Up in a town known as Tyrone, Pennsylvania; was a 42k mile L67.
- Once I got the engine home and onto my stand, I started the tear down. I then quickly discovered that the cooling system was completely gummed up with a hard, crystalized, fish smelling gunk. fortunately, the oil passages and or anywhere that would see oil looked pretty much brand new. From there, I decided to have the block completely cleaned by a machine shop. So I tore down the engine completely and sent it off to be cleaned.
- Fresh out of the machine shop! My block looks brand new. While the block was being cleaned, I decided I wanted to paint the block and heads. I picked up a can of rusty metal primer, and royal blue brush on paint from my local Lowe's and got to work. wiped the entire block down with acetone, one coat of rusty metal primer, and two coats of royal blue all with a 24 wait time in-between for drying.
- After I painted the block, I had a friend of mine shine up my gen V Eaton m90 blower that was going to go onto the car.
- Once my block and blower were ready, I started to assemble the engine.
- I completely rebuilt this engine from the bottom up, and also modded it That includes:
- Main Bearings
- Rod Bearings
- New Stock TTY Bolts
- Oil Pump
- Every Gasket
- INTENSE S1X Blower cam
- LS7 Lifters
- 105# Valve Springs
- Single Roller Rollmaster Chain set
- 42.5# Fuel Injectors
- ZZP Shortstack Intercooler
- Gen V eaton M90 Blower
- 3.4 Supercharger Pulley
- Northstar Throttle Body
- LQ4 Mass Air Flow Sensor
- INTENSE 4" Fenderwell Intake
- ZZP Polished Aluminum Valve covers
- 160 Amp Alternator
*Note everything from here is just problems / maintenance*
- Once the engine was in the car, I quickly hooked the harness and everything else in preparation for the first start. To my surprise, it turned over immediately. Unfortunately I wouldn't notice a major issue it had until a few days went by and showing friends that it ran. The engine had no oil pressure!
- I spent September troubleshooting why I had no oil pressure. Through multiple forums and asking around, nobody, nor I could figure it out. Till one day on facebook, a user pointed out that I may be missing two oil plus right above the camshaft that will kill oil pressure if removed. Fortunately that was the solution! I mistakenly removed them during the build process because I thought that they weren't supposed to be there.
- I doll everything back together, found the right caps, and wow! the engine purrs and has oil pressure!
- From here till December, 2024 (current,) I have not made any major changes or modifications to the engine other than tuning. I will update in the future with any changes
- October, 2022 - August, 2023
- Once I removed the transmission from the car, I set it aside.
- I didn't really intend to build the transmission in anyway because through research, I came to the conclusion that with the power that I was going to make, a stock trans with some hop-ups would do. the only things I did to my transmission include:
- TRANSGO Shift Kit
- Trucool 40k Cooler
- 2500 Stall Torque Converter
- New Oil Pump
- New Solenoids
- New Harness
- New Fluid
- New Filter
- Before I finished the engine, I traded my old motor short block for a 2500 stall zzp torque converter
- I also pulled the transmission out of the garage, degreased and deep cleaned it.
- Yay! the car runs. But wait a minute... The transmission will not engage at all while in Drive. However it will manually grab 1, 2, and 3 when manually commanded through the shifter.
- Some troubleshooting later from Rob himself, he had me replace all of the solenoids and the internal harness.
- While doing that job, I thought that I had to remove the trans oil pump to gain access to the last solenoid. While removing it, I wasn't careful enough and it completely fell apart while taking it out.
- Once I got a new pump, I was able to finish up the job and the car now drove normally.
- From there, I haven't touched the transmission outside of tuning since.
- This will not happen anytime soon but I have a 4t80e that I bought December, 2023 that I will be swapping into the car in the future when my 4t65e-HD blows up
- October, 2022 - December, 2024 (Current)
- My exhaust hasn't changed since I planned it out back in October, 2022. The exhaust is as follows:
- ZZP Stainless Steel Power Logs
- ZZP Equalizer Downpipe
- ZZP TOG Downpipe W/ High Flow Cat
- No Resonator
- Single Boorla XR-1 Muffler in place of a resonator
- Y-pipe
- Stock Bonneville SSEi Cowbell Tips
Suspension & Steering:
- October, 2022 - September, 2023
- It's no secret that the Bonneville / GM H G body platform has little to zero aftermarket suspension pieces.
- While I was working on the engine, one of the outer tie rods mushroomed out and got stuck in the knuckle
- I decided to replace the entirety of the front end suspension because it was all old and high mileage. All of that includes:
- Remanufactured Magnasteer Steering Rack
- Inner Tie Rods
- Outer Tie Rods
- Wheel Bearings
- Sway Bar End Links
- Control arms
- Struts
- I bought and installed rear oem air shocks to replace the quick struts that raise the car 2"
- I took the 2" lift kit springs off of my new struts and replaced them with the stock Bonneville SSEi springs to bring back stock ride height all around
- I have ordered a Strut Bar from a Bonneville GXP to install on my car over the winter
- I will be purchasing 2" lowering springs to give a nice low look to the car
- Nothing really much to put here, I replaced the brakes all around.
- Front: Bonneville GXP Dual piston Red calipers and the rest of the GXP brake kit
- Rear: Stock Spec Bonneville SSEi brakes but with Red Calipers
- I don't plan on changing this anytime soon
- June, 2023 - October, 2024
- By going to various junkyards and buying stuff online, I have secured just about a full GXP body kit and interior swap for my car (Pictures in album)
I want to thank you for reading my post about the journey I've taken to build my car. Even with all of this, it only covers roughly two years of me owning this car. I have owned this car since December, 2020; I have basically rebuilt this whole car and I am nowhere near done.
There is way more to come!
Thanks!
-Christian
Link to Photo Album
