1997-2004 GM N body passlock bypass
Jasmindont
Uploading a downloadable PDF guide to bypassing the passlock system in your 1997-2004 GM N body car which include:
1997-2003 Chevrolet Malibu
1999-2004 Oldsmobile Alero
1999-2004 Pontiac Grand AM
Step by Step guide.
Step-by-Step Guide for N-Body Security Bypass (No Solder Method)​
This guide provides a detailed, step-by-step walkthrough of the N-Body security bypass method for GM vehicles. The no-solder approach simplifies the process, ensuring an effective and accessible solution for bypassing the Passlock security system.
Step 1: Prepare Your Workspace​
Ensure you have a clean and well-lit workspace. Gather the necessary tools, including a screwdriver, electrical tape, and a wire stripper.
Add Image Here: Workspace Setup
Step 2: Disconnect the Battery​
For safety, disconnect the vehicle's battery by removing the negative cable. This step prevents accidental electrical shorts.
Add Image Here: Disconnecting the Battery
Step 3: Access the Ignition Module​
Remove the dashboard panel to access the ignition module. Use a screwdriver to carefully detach the panel.
Add Image Here: Accessing Ignition Module
Step 4: Locate the Passlock Wires​
Identify the Passlock wires connected to the ignition module. Refer to the vehicle's wiring diagram for exact colors and placement.
Add Image Here: Locating Passlock Wires
Step 5: Bypass the Passlock System​
Follow these steps to bypass the Passlock system:
1. Cut the Passlock wire.
2. Strip both ends of the wire.
3. Connect the ends with an inline resistor (as specified in the guide).
4. Secure the connection with electrical tape.
Add Image Here: Bypassing Passlock
Step 6: Reassemble the Dashboard​
Reattach the dashboard panel and secure it with screws. Ensure all components are properly aligned.
Add Image Here: Reassembling Dashboard
Step 7: Reconnect the Battery​
Reconnect the vehicle's battery by attaching the negative cable. Start the car to confirm the bypass was successful.
Add Image Here: Reconnecting Battery
Congratulations! You have successfully bypassed the Passlock security system using the no-solder method. If you encounter any issues, double-check your connections or consult a professional.
