- 121
Hello everybody!
As many of you may know, I’ve decided to take on Version 2 of my LFX-swapped Monte Carlo project! This time, I’ll be working with a 2006-2007 Monte Carlo as the base, and a 2012-2016 W-body Impala as the donor vehicle.
This thread will document the entire process, including:
• How everything is done
• The parts I’ll be gathering over the winter (to get a head start for spring/summer)
• Suspension, interior, and all the upgrades
The ultimate goal? 300 WHP with a fully upgraded suspension, a custom interior, and everything completely functional (well… except the HVAC, lol).
Here’s a list of almost everything I want to do! Probably forgot some stuff, but it’s mostly there.
Engine
Tune
Intake
Mace cams
Mace valve springs
Intake plenum spacer
High flow downpipes
Throttlebody swap
Underdrive pulley
Oil cooler from police impala
solid motor mounts
Transmission
Big Cooler
Shift kit
Tune
Swap to 6t75e
3.16 gear swap
Solid transmission mount
Brakes
12.7 inch 4 piston brakes
12 inch rear grand prix gxp brakes
Goodridge stainless braided hoses
High quality complete fluid flush
Suspension
tubular subframe
Front strut tower brace
Rear strut tower brace
tubular rear control arms
tubular front control arms
front sway bar
rear sway bar
coilovers
Tubular rear subframe
Solid front subframe bushings
Exhaust
Cat delete
magnaflow catback
Wheels/tires
18x9.5 +35 offset rims
265/40/18 pilot sport 4s tires
Might need 10mm spacers
Interior
Led interior lights
Aftermarket seats
Rear seat delete
Equinox steering wheel
Complete HVAC delete
Complete audio system overhaul
Exterior
Paint underbody
00-05 Monte SS HS front end swap
New headlights
Stick around and follow along—it’s going to be a hell of a build! Can’t wait to share the progress and hear your thoughts along the way!
Engine
Tune
Intake
Mace cams
Mace valve springs
High flow downpipes
Throttlebody swap
Underdrive pulley
solid motor mounts
Transmission
Big Cooler
Shift kit
Tune
Swap to 6t75e
3.16 gear swap
Brakes
Suspension
tubular subframe
front sway bar
rear sway bar
coilovers
Exhaust
Cat delete
magnaflow catback
Wheels/tires
Interior
Led interior lights
Aftermarket seats
Rear seat delete
Exterior
Paint underbody
New headlights
