- 139
Engine and Powertrain Mods
If you’re after serious power, forced induction is the way to go. Adding a supercharger or turbocharger will significantly increase horsepower, but be warned—this route is far more complex and requires careful planning and setup.
Keep in mind that adding forced induction requires a custom setup, as the stock engine wasn’t designed for this type of power. You'll need custom fabrication, a proper intercooler, stronger fuel injectors, upgraded fuel system, and extensive tuning. Forced induction is a more advanced and complex route than simple bolt-ons, but it’s the ultimate path for serious performance gains.
Why E85 is Great for More Power in Your LFX Engine
E85, a blend of 85% ethanol and 15% gasoline, is an excellent choice for boosting performance in your LFX engine. It offers several advantages:
Disclaimer:
Please note that some of the parts and upgrades mentioned in this guide may no longer be readily available, particularly intake manifold spacers, which may require custom fabrication or sourcing alternatives. However, for intakes, camshafts, and most other parts, these remain available for purchase through various vendors, though availability can vary depending on your location or the specific part.
Before beginning your build, make sure to check the availability of all parts. If certain components are hard to find, consider reaching out to the community or specialized shops for custom solutions. Custom fabrication can be a great alternative, but be prepared for additional time and effort.
Good luck with your build, and I hope everything goes smoothly!
- PowerBond Underdrive Pulley
- 25% Underdrive Pulley by Power Bond: Shifts the power curve for quicker throttle response and improved performance.
- Part Number PB621-A
- Cold Air Intakes
- K&N Cold Air Intake: A tried-and-true upgrade to improve airflow.
- Part number 69-4526TS
- Overkill Motorsport ASI Intake: Larger 3.5-inch diameter, designed for maximum airflow. Requires tuning for optimal performance.
- Part Number N/A
- Airflow Dynamics Intake: Another high-performance option for better airflow and cooler intake temperatures.
- Part Number 1314-CI-HS
- Custom 3.5-Inch Fender well Intake: A DIY option that pulls cool air from outside the engine bay, reducing heat soak and enhancing performance.
- Part Number DIY
- Intake Manifold Spacer
- JacFab 3.5-inch Spacer: Proven to improve intake airflow and performance compared to smaller spacers.
- Part Number N/A
- Throttle Body
- 80mm Throttle Body by Overkill Motorsport: Enhances airflow and throttle responsiveness, paired with a spacer adapter for easy installation.
- Part Number N/A
- Magnaflow Downpipes
- Performance Downpipes: Adds up to 20 whp and 22 wtq by improving exhaust flow and reducing backpressure, making it a highly effective bolt-on upgrade.
- Part Numbers 52184 (front) 52185 (rear) 52107 (middle)
- MACE Camshaft Upgrade
- Adds up to 35 whp with the correct tuning. A significant boost to top-end power, making it a perfect match for other bolt-ons.
- Part Number CAM669-A
- Catch Can
- Direct injection engines like the LFX are prone to carbon buildup on intake valves. Installing a catch can reduces oil blow-by and helps maintain long-term engine health and performance.
- Part Number (no direct fit catch cans are available, make a custom set up)
- Tuning Options
- Overkill Tune: Tailored for the LFX platform, delivering better power, torque, and drivability.
- Part Number LINK
- Custom HP Tuners Tune: Allows for complete customization of your engine parameters, ideal for advanced setups.
- Part number HPTUNER MPVIx
- Trifecta Tune: A simpler, plug-and-play option for those seeking a hassle-free tuning solution.
- Part Number LINK
- Transmission Swap
- 6T75E Transmission:
- An easy and effective upgrade, offering a stronger transmission with better durability.
- Choose a 2.77 or 3.16 final drive ratio for improved acceleration and overall performance.
- Part Number JUNKYARD OR NEW
- With the simple bolt-ons and tuning, expect 280-300 whp with excellent drivability.
- Adding the MACE camshafts can push output to 320-330 whp, equivalent to 430-450 bhp.
- The 6T75E transmission swap ensures smooth power delivery and reliability under higher output.
- Supercharger: Adding a supercharger can push your LFX engine to 400-500 whp, depending on the setup and tuning. A supercharger provides instant power and torque, making it ideal for street and track use.
- Turbocharger: A turbocharger setup can yield similar results, often reaching 450-500 whp, with the added benefit of better fuel efficiency compared to a supercharger. However, turbo setups are more complicated and may require additional modifications like intercoolers, piping, and custom tuning.
- Rebuilding the Bottom End: To safely run forced induction, you may need to lower the compression ratio of your engine. This involves rebuilding the bottom end with forged internals (e.g., pistons, rods) to handle the added boost pressure. This is a must-do for higher boost levels and ensures long-term reliability under forced induction.
- Increased Power: E85’s higher octane allows for more aggressive tuning and higher boost, increasing power by up to 10-15%.
- Cooler Combustion: The ethanol burns cooler than gasoline, reducing the risk of knocking and allowing your engine to run safely under higher stress.
- No Need for Upgrades: E85 can be used without needing modifications to your fuel system. It’s safe for the stock setup, making it an easy and cost-effective way to boost power.
Disclaimer:
