Swapping 2004+ Grand Prix seats into a 1997-2003 Grand Prix requires proper wiring to ensure power seat movement and heated seat functionality (if equipped). This guide will walk you through the...
Replies
2
Views
376
gs_geoff
As most of you know, GM was on the verge of Bankruptcy in the early to mid-aughts (and eventually filed bankruptcy in 2009.) Due to this, they did a LOT of parts sharing between divisions to save...
Replies
4
Views
311
Certified Shadetree
The 9th Gen Impala has a keyfob that's shared with virtually every GM vehicle from the same era (2006-2013) If you look at the back of your stock fob, you'll see the FCC ID of OUC60370. Not only...
Replies
1
Views
156
ThatSlow.W204
It’s cold out and I thought my heated seats worked. It seems like they aren’t working though. The light comes on at the switch for high or low. Has anyone ever messed with these before I get into it?
Replies
2
Views
186
Certified Shadetree
This guide explains how to bypass the fuel pump on a Pontiac Grand Prix GT to keep it constantly running. This modification should be undertaken with caution. Ensure you follow all safety...
Replies
Views
152
This document provides the pinout details for the Ignition Control Module (ICM) used in 1988-1994 and similar GM vehicles equipped with the 3.1L V6 engine and Distributorless Ignition System...
Replies
Views
144
