Electrical Systems
GM W-Body electrical diagnostics and repair help for wiring, charging, starting, modules, sensors, grounds and common electrical faults.
Swapping 2004+ Grand Prix seats into a 1997-2003 Grand Prix requires proper wiring to ensure power seat movement and heated seat functionality (if equipped). This guide will walk you through the...
Replies
4
Views
2K
Hello, hope you are doing well, I just bought a 1995 Buick Regal Custom with the 3.1L V6. My ABS light is on and the seller told me that its a faulty wheel speed sensor. Also sometimes when I...
Replies
5
Views
2K
90blkgt
As most of you know, GM was on the verge of Bankruptcy in the early to mid-aughts (and eventually filed bankruptcy in 2009.) Due to this, they did a LOT of parts sharing between divisions to save...
Replies
4
Views
895
Certified Shadetree
The 9th Gen Impala has a keyfob that's shared with virtually every GM vehicle from the same era (2006-2013) If you look at the back of your stock fob, you'll see the FCC ID of OUC60370. Not only...
Replies
1
Views
1K
ThatSlow.W204
It’s cold out and I thought my heated seats worked. It seems like they aren’t working though. The light comes on at the switch for high or low. Has anyone ever messed with these before I get into it?
Replies
2
Views
592
Certified Shadetree
This document provides the pinout details for the Ignition Control Module (ICM) used in 1988-1994 and similar GM vehicles equipped with the 3.1L V6 engine and Distributorless Ignition System...
Replies
Views
536
