- 270
Hey everyone,
I’m starting to put together a long-term plan for my 1997 Honda Civic EK, and I’ve decided to aim for a budget-friendly K-swap as my starter build. I don’t have a set timeline yet, but this is something I want to work toward steadily. My goal is to keep it affordable, reliable, and plug-and-play friendly — with room to upgrade down the road (whether that’s NA tuning or boost).
Here’s the plan I’ve put together so far:
- Engine: K24A4 or K24A8 (CR-V/Accord) – great torque, low cost
- Transmission: K20A2 or K20Z1 (RSX Type-S) – better gearing than stock K24 trans
- Clutch/Flywheel: Stock K-series or lightened upgrade
- Optional: K20 oil pump swap if I go higher RPM later
- Mount Kit: Hasport EKK2 (for K20 trans) or Innovative for budget
- Axles: K-swap specific axles (Hasport, Insane Shafts, etc.)
- Shifter Setup: Hybrid Racing or K-Tuned shifter box + cables
- Harness: Plug-and-play from Rywire or K-Tuned
- ECU: 02–04 RSX Type-S ECU (Hondata KPro ready)
- Tuning: KPro v4 for full control, or KTuner for a cheaper start
- K-swap throttle cable
- Custom intake and exhaust header for EK chassis
- Fuel line adapter kit
- Radiator hoses + cooling solution
- Speed sensor adapter (if using newer trans)
Rough range: $3,800–$5,500 depending on parts sourced and tuning path.
- K20 head swap or K20Z3 full build
- Turbo kit once the base swap is dialed in
- ITBs if I stay NA
- LSD and brake upgrades once power increases
I’ll keep this thread updated as I gather parts or make decisions. If anyone’s done a similar swap or has advice for sourcing parts on a budget — I’m all ears. Would love to get feedback from others who started with a basic K24 build and upgraded over time.
Thanks for reading,
