As most of you know, GM was on the verge of Bankruptcy in the early to mid-aughts (and eventually filed bankruptcy in 2009.) Due to this, they did a LOT of parts sharing between divisions to save...
The 9th Gen Impala has a keyfob that's shared with virtually every GM vehicle from the same era (2006-2013) If you look at the back of your stock fob, you'll see the FCC ID of OUC60370. Not only...
