The L82 ("M-code") was an updated, SFI replacement for the MPFI LH0, produced from 1993 through 1999. It featured a structural oil pan, a stiffer redesigned engine block, sequential fuel injection, and revised aluminum heads. Output for the L82 was up 20 hp (15 kW), over the previous Gen II LH0, to 160 hp (119 kW) at 5200 rpm and 185 lb⋅ft (251 N⋅m) at 4000 rpm. Compression ratio for the L82 was 9.5:1 and the bore measured 89 mm (3.5 in), while the stroke was 84 mm (3.31 in) giving it a displacement of 3.1 L; 191.3 cu in (3,135 cc)
