3.8 L L67 SC V6
The L67 is the supercharged version of the 3800 Series II L36 and appeared in 1996, one year after the naturally aspirated version. It uses the Eaton Generation III M90 supercharger with a 3.8 in (97 mm) pulley, a larger throttle body, and different fuel injectors, different cylinder heads, as well as different lower intake manifold and pistons than the L36 uses. Both engines share the same engine blocks, but compression is reduced from 9.4:1 in the L36 to 8.5:1 for the L67. GM listed the engine output as 240 hp (179 kW) and 280 lb⋅ft (380 N⋅m) of torque. Final drive ratios are reduced in most applications, for better fuel economy and for improved use of the engine's torque in the low RPM range. Like most 3800 V6s, the engine is well known for its reliability and low maintenance costs. The engine is a popular choice for aftermarket modification thanks to its very strong internals and impressive power gains from basic upgrades. The engine was built in Flint, Michigan, and was certified LEV in 2001.
    • Like
These are the specs of the cams sold by INTENSE Racing that I could find online. All credit goes to them CAM-6705 - INTENSE™ Stage 1 Blower Cam, duration @ .050": 209/204, lobe lifts: .305"/.298"...
Replies
4
Views
262
RegalRacer
    • Like
I just got done doing an upper and lower intake gasket, opened up my stock air box and cut out the U bend out of the exhaust on my regal gs. Other than that it’s completely stock. I have recently...
Replies
6
Views
296
RegalRacer
Alright lads as promised here's my SUPERCORE 2.5inch intercooler write up. What's involved, how it went, what happened etc. If there are any questions more photos needed etc please pm me or ask in...
Replies
Views
90
RegalRacer
Top Bottom
