The LZE 3500 is an OHV flexible fuel engine based on the 3.5L LZ4 V6 (it can use either plain gasoline or 15% Gasoline and 85% Ethanol, E85) and includes continuously variable cam timing (fixed overlap). It has a cast iron block and aluminum heads. Bore and stroke is 99 mm × 76 mm (3.90 in × 2.99 in), for a displacement of 3.5 L; 214.2 cu in (3,510 cc). Output is 211 hp (157 kW) at 5800 rpm and 216 lb⋅ft (293 N⋅m) at 4000 rpm.
