A smaller 3.3 liter 3300 was introduced in 1989 and produced through 1993. It was effectively a lower-deck version of the 3800, with a smaller bore and stroke of 3.7 in × 3.16 in (94.0 mm × 80.3 mm) for 3,340 cc (3.3 L; 203.8 cu in).[4] Like the 3800, it used a cast iron block and heads, push rods, and hydraulic lifters. Unlike the 3800, however, it used a batch-fire injection system rather than sequential injection, as evidenced by the lack of a cam position sensor. It also did not have a balance shaft. Power output was 160 hp (119 kW) at 5,200 rpm and 185 lb⋅ft (251 N⋅m) at 2,000 rpm with a 5,500 rpm redline.
Trying to install a aftermarket tachometer on a 93 Buick century 3.3l v6 and don’t really know what I’m doing and want to do it correctly I don’t have a stock tachometer but I do have the wire on...
